Serial overrun error
dnishimura
Post by dnishimura »
Periodically when reading off the UART1 using ReadWithTimeout, I get a overrun error as reported from GetUartErrorReg. There's no way the buffer is being overrun by the small amount of data that is being received. Are there any other conditions that would cause this error? I used both NNDK 2.7.1 and NNDK 2.7.0 on SB70LC.
Re: Serial overrun error
You opened the serial port with openserial, not just leaving the polled normal startup in place?
What other code do you have running that might cause interrupts to turn off?
dnishimura
Yes I closed the serial port and reopened the port with openserial before reading from the port.
I am reading from the serial port in one task and sending data out on the IP network in another task. Would anything there cause interrupts to turn off?
Can you post your reading code?
Also what exact value are you getting for
GetUartErrorReg.
dnishimura
I emailed you the code. The error code that's returned is 1.
Don't see anything obviously wrong....
What baud rate are you running.... (IE is it a non-standard baud rate)
What do all of your log functions do time wise?
What sort of data are you receiving and at what rate?
Show me the details of opening the serial port ie what does
reset_serial(); do exactly.
What other tasks are running....
Also is this in release or debug?
If its in debug and you are stopped in the debugger the serial interrup cant fire and you will get overflows...
dnishimura
Happens in both debug and release without any breakpoints.
I think you missed the majority of his questions. He'll probably need those answers to help you.
dnishimura
Ah yes sorry...overlooked the first set of questions:
1) baudrate: 115200, stopbits: 1, databits: 8, no parity
2) We are receiving just ascii data in packets of 24 to 49 characters. On average we get about 1 packet per second.
3) log functions are just a wrapper around iprintf with some additional info added in.
4) reset_serial() code here:
int reset_serial()
    int gateway;
    SerialClose(1);
    gateway = OpenSerial(1, 115200, 1, 8, eParityNone);
    writestring(gateway, "!Gateway\r\n");
    return gateway;
5) The other task that's running is a task that sends data the data read from the serial port to a webserver using the SSL library (SSL_connect). There are no shared data between the tasks besides data that's passed between the tasks using OS_FIFO.
