Console output not appearing
Posted: Mon May 19, 2014 10:27 am
This is probably a stupid question but I am new to the netburner and embedded programming in general so please bear with me. I am starting from a fresh netburner project template which has DHCP, AutoUpdate, and Network Debugging enabled. I am able to launch the program in debug mode and have confirmed it is running properly on the device via breakpoints. My issue is that in the template created, there is a line:
that I assumed was supposed to output that message to the console in Eclipse, but this message never appears in any console whether launched as run or debug. I tried using the "Display Selected Console" button on the console tab itself to select through the four different consoles but I don't see the output there either. I have tried placing the iprintf statement inside my while loop so that it should output repeatedly, and have breakpointed while in the loop to confirm the line is getting executed but still no output is seen. I'm guessing this is something really simple I'm missing with an IDE setting. Thanks for your help
