NANO54415 Simple WAV Player Issues
Posted: Wed Mar 12, 2014 5:28 pm
I have searched the forums for anyone else having issues with the NANO54415 Simple WAV Player demo solution and have not found anything. I have been using the MOD5282 for many years now, but have just recently purchased the NANO. I have imported the NANO54415 Simple WAV Player solution files into a newly created project, cleaned the solution, and tried to rebuild with no luck. I keep getting lots of errors, and I assume that I am missing something specific to the NANO development. I am also getting similar issues with the NANO54415 WAV Player demo solution. Here are all of the errors, any guidance would be greatly appreciated.
Thanks - Mark
Description Resource Path Location Type
'sim1' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 143 C/C++ Problem
'sim1' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 472 C/C++ Problem
'sim1' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 580 C/C++ Problem
'sim1' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 641 C/C++ Problem
'sim1' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 671 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 66 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 97 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 123 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 204 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 473 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 643 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 667 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 703 C/C++ Problem
'sim2' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 717 C/C++ Problem
'simTimer_' was not declared in this scope NANO54415 Simple WAV Player line 117, external location: C:\nburn\NANO54415\include\HiResTimer.h C/C++ Problem
'simTimer_' was not declared in this scope NANO54415 Simple WAV Player line 128, external location: C:\nburn\NANO54415\include\HiResTimer.h C/C++ Problem
'simTimer_' was not declared in this scope NANO54415 Simple WAV Player line 140, external location: C:\nburn\NANO54415\include\HiResTimer.h C/C++ Problem
'simTimer_' was not declared in this scope NANO54415 Simple WAV Player line 151, external location: C:\nburn\NANO54415\include\HiResTimer.h C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 167 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 176 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 177 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 181 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 182 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 204 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 459 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 466 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 469 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 525 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'dac' WavPlayer.cpp /NANO54415 Simple WAV Player line 555 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'tcd' WavPlayer.cpp /NANO54415 Simple WAV Player line 168 C/C++ Problem
'struct WavPlayer::channelControl' has no member named 'tcd' WavPlayer.cpp /NANO54415 Simple WAV Player line 205 C/C++ Problem
'tcd' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 92 C/C++ Problem
'tcd' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 95 C/C++ Problem
'tcd' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 115 C/C++ Problem
'tcd' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 519 C/C++ Problem
'tcd' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 549 C/C++ Problem
'timer' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 139 C/C++ Problem
'timer' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 633 C/C++ Problem
'timerSettings' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 587 C/C++ Problem
'timerSettings' was not declared in this scope WavPlayer.cpp /NANO54415 Simple WAV Player line 633 C/C++ Problem
'timerstruct' does not name a type WavPlayer.h /NANO54415 Simple WAV Player line 226 C/C++ Problem
#error PROCESSOR_NOT_DEFINED NANO54415 Simple WAV Player line 50, external location: C:\nburn\include\sim.h C/C++ Problem
expected ';' before '*' token NANO54415 Simple WAV Player line 78, external location: C:\nburn\NANO54415\include\HiResTimer.h C/C++ Problem
expected ';' before '*' token WavPlayer.h /NANO54415 Simple WAV Player line 198 C/C++ Problem
expected ';' before '*' token WavPlayer.h /NANO54415 Simple WAV Player line 199 C/C++ Problem
expected initializer before '&' token WavPlayer.cpp /NANO54415 Simple WAV Player line 89 C/C++ Problem
expected initializer before '&' token WavPlayer.cpp /NANO54415 Simple WAV Player line 138 C/C++ Problem
expected initializer before '&' token WavPlayer.cpp /NANO54415 Simple WAV Player line 502 C/C++ Problem
expected initializer before '&' token WavPlayer.cpp /NANO54415 Simple WAV Player line 602 C/C++ Problem
ISO C++ forbids declaration of 'dacstruct' with no type WavPlayer.h /NANO54415 Simple WAV Player line 198 C/C++ Problem
ISO C++ forbids declaration of 'edma_tcdstruct' with no type WavPlayer.h /NANO54415 Simple WAV Player line 199 C/C++ Problem
ISO C++ forbids declaration of 'timerstruct' with no type NANO54415 Simple WAV Player line 78, external location: C:\nburn\NANO54415\include\HiResTimer.h C/C++ Problem
Thanks - Mark
