Reading a webpage with Netburner?
barttech
Post by barttech »
I suspect this is basic, but how can I read a webpage with my MOD5234?
I see (and have made) all sorts of ways to serve webpages. I want to have my device get some parameters from the DSL modem at 192.168.1.1. Do I have to do an FTP?
Sam
Re: Reading a webpage with Netburner?
A web browser request to a server is basically a TCP connection and GET or POST request. You need two consecutive line feeds after the GET. There is an example of this in the NetBurner weather demo: http://demo.netburner.com:81/INDEX.HTM.
I'm actually in the middle of generating some examples of this....
Here is a snipit of known workign code that does this...
Before you get to this code you need to have turned the name into an IP address
and put it in the ip variable
and put the text of the request into tRequest...
In this example the code that fills in the tRequest is here:
if(GetHostByName(pAddress,&ip,0,SLEEP_INTERVAL.tval())==DNS_OK)
iprintf("IP Address ="); ShowIP(ip);
siprintf(tRequest,"GET /%s?%s HTTP/1.1\r\nHost:%s\r\n\r\n",pUrl,DEVICENAME.string(),pAddress);
iprintf("Request =[%s]\r\n",tRequest);
LedState=LED_NO_DNS_RESOLVE;
iprintf("Failed to get DNS address\r\n");
//Now connect and get the result....
int fd=connect(ip,0,OUTBOUND_PORT.wval(),SLEEP_INTERVAL.tval());
if(fd<0)
LedState=LED_NO_SERVER_CONNECT;
ip=0;
LastConTime=TimeTick;
writestring(fd,tRequest);
int nread=0;
while(1)
int rv=ReadWithTimeout(fd,tResponse+nread,RESPONSE_SIZE-nread,REQUEST_TIMEOUT.tval());
if(bLog) iprintf("Read at %ld\r\n",TimeTick-LastStartTime);
if(rv>0)
{nread+=rv;
if(nread>=(RESPONSE_SIZE-1)) break;
tResponse[nread]=0;
break;
LastReadDoneTime=TimeTick;
if(nread)
nRequests++;
char * FindResult= strstr(tResponse,"\r\n\r\n");
if(FindResult)
{//Process the returned data
close(fd);
barttech
Post by barttech »
Thanks, both are useful. Getting weather information was one of my objectives, I had forgotten about the demos.
Sam
