multiple text backgrounds
Posted: Wed Aug 07, 2013 2:23 pm
by cbein
I am working on a project that contains a lot of code, and I am trying to figure out a way to change the background or highlight certain parts of the code. Different backgrounds for functions, declarations, loops, etc... would just debugging easier.
Is there a way to do this in the Netburner's Eclipse IDE? I know this is possible in Notepad++ or similar editors, but I would prefer not to switch back and forth. I apologize if this should be obvious, but I have not had any luck finding an answer.
Re: multiple text backgrounds
Posted: Wed Aug 07, 2013 3:15 pm
Use Quick Access (the default keystroke is Ctrl-3) and type color. In the list you'll see the preference setting for C++ syntax coloring (see image). Use this to see if you can get what you're after. (You'll also notice there are other coloring options).
<Promo>I just finished recording my Eclipse course for Pluralsight. It's in the editorial review process right now. Hopefully it will be live soon! </Promo>
- QuickAccessSyntaxColor.png (16.23 KiB) Viewed 16009 times
Posted: Wed Aug 07, 2013 3:44 pm
by cbein
I am not sure this has what I want to do. I understand that I can change the syntax coloring, but basically, I want to be able to highlight a section of code and give it a different style/color. This way I can make say lines 50-200 have a yellow background and lines 200-400 have a blue background.
I don't think I can do this through preferences since the adjustments made always apply to the entire document.
Posted: Wed Aug 07, 2013 4:04 pm
by Forrest
This is not possible in eclipse afaik. Not sure if it would help, but you can enable code folding to hide code you are not working on
cbein wrote:I am not sure this has what I want to do. I understand that I can change the syntax coloring, but basically, I want to be able to highlight a section of code and give it a different style/color. This way I can make say lines 50-200 have a yellow background and lines 200-400 have a blue background.
Posted: Wed Aug 07, 2013 4:17 pm
by cbein
Thanks. I think code folding will be the best alternative.
Posted: Wed Aug 07, 2013 6:40 pm
I did some searching and I can't even find a plug-in that does this. On the code folding approach, you can turn on code folding for pre-processor directives and then surround multiple methods with
#if (true)
#endif
and do code folding similar to how regions work in C#.
Posted: Wed Dec 17, 2014 2:38 am
by lisaa
Awesome work, thanks!!!
