EMI Reduction with MOD5441X and NANO54415
Posted: Mon Jul 29, 2013 11:20 am
Recently, we've seen a couple cases where designs using the MOD5441X have had issue with FCC certification due to RF radiation. In both cases they were seeing failures with harmonics of 125 MHz. On their own, both the MOD5441X and the carrier board were within limits, both fully assembled the device could not pass. One thing that you as a designer/user can do to reduce the strength of 125 MHz harmonics is to disable unused peripherals.
A little explanation for the uninitiated: the MCF54415 processor on these modules runs at a default core clock speed of 250 MHz. This is generated using a PLL in the processor from a 25 MHz crystal on the module. This 250 MHz core clock is then scaled by a factor of 2 to 125 MHz to create the clock signal that is fed into the peripheral modules of the processor. These modules are then clocking and drawing power at some subharmonic of 125 MHz. By disabling the clock to a peripheral module, that module will no longer have a varying load; it may still draw some power, but significantly less, and more importantly, it will do so in a DC manner.
So how do you do this? By writing to the Peripheral Power Management Registers (MCF54415 Reference Manual 9.2) and turning on the bit associated with the peripheral module. You can do an 'all at once', by read, modify, writing to the Peripheral Power Management Registers (section 9.2.4) or you can selectively enable/disable modules one at a time by writing to the Peripheral Power Management Clear (section 9.2.3) or the Peripheral Power Management Set (section 9.2.2).
I have made a header file which will facilitate this process. It defines macros that will write to the Set/Clear register pair to individually disable/enable modules. The format of the macros are as follows:
Example:
For peripherals with multiple submodules, the format is as follows:
Example:
PERIPH_DISABLE_<MODULE NAME>
PERIPH_ENABLE_<MODULE NAME>Code: Select all
PERIPH_DISABLE_FLEXBUS
PERIPH_ENABLE_FLEXBUSCode: Select all
PERIPH_DISABLE_<MODULE NAME>_<SUBMODULE NUMBER>
PERIPH_ENABLE_<MODULE NAME>_<SUBMODULE NUMBER>Code: Select all
PERIPH_DISABLE_DSPI_1
PERIPH_ENABLE_DSPI_1
