moving NNDk installation to a new machine
Posted: Mon Apr 15, 2013 7:55 pm
by roland.ames
I currently have NNDK Rel24_rc2 installed on a windows XP machine. I am about to upgrade to a new 64 bit windows 8 machine. What do I have to do to migrate to the new machine, keeping the relevant MOD libraries for the development kits I have previously installed? Is there anything I need to do or should be aware of?
Roland
---EDIT---
that should be 64 bit windows 7
Re: moving NNDk installation to a new machine
Posted: Wed Apr 17, 2013 11:45 am
You will need the registration numbers for all your dev kits. If you use NBEclipse that will install a 32 bit customized version of Eclipse that should work fine. If you want to install Indigo, Juno or Helios (I recommend Indigo) releases I would stick with a 32 bit version. I had no luck with 64 bit versions.
Posted: Wed Apr 17, 2013 12:35 pm
I think you need the 32-bit version of java installed as well.
Posted: Wed May 01, 2013 8:48 pm
by roland.ames
thanks for your info, I also found something in the wiki:
http://wiki.embeddedethernet.com/Suppor ... dows_7.2F8
can anyone confirm which versions of the NNDK are suitable for windows 7 ?
