Is there a schematic for the NANO54415 Development Kit
Posted: Thu Feb 07, 2013 6:58 am
by Lachlanp
I want to use thye NNDK to connect to other harware. In the NNDK documentation I cannot find a schematic or even any details about the hardware.
How can I get the signal pinouts of P2 & P3 connectors
Regards
Lachlan
Re: Is there a schematic for the NANO54415 Development Kit
Posted: Thu Feb 07, 2013 8:02 am
There should be a document in your 'nburn/docs/Platform/Schematics/ folder called 'NANO-ADAPT-100...'. This is the schematic for the dev board.
What I think your getting at is "Why do the pins not work?". The answer for that is that the P2 and P3 headers mirror the actual Nano edge connector, but the odd/even pins are backwards. Pin 1 of P2 is pin 2 on the data sheet and Pin 2 of P2 is pin 1 on the data sheet (also pin 1 of P3 is pin 18, and pin 2 of P3 is pin 17). We realize that there's an issue here, and we're working on finding the right solution. If you have any feedback on what you would expect from the labeling/recommendations, let us know.
Hope that helps.
Posted: Thu Feb 07, 2013 10:55 pm
by Lachlanp
Cannot fuind a schematic in the location indicated.
Under docs/platform, i can only find one document referenceing the Nano54415 which indicates the memory Map and the RJ45 connector details. There is nothring related to the Nano or Nano adapter under schematic.
Regards
Lachlan
Posted: Fri Feb 08, 2013 4:37 am
by seulater
Are you running the latest software RELEASE 2.6.0 (September 2012) ?
Posted: Fri Feb 08, 2013 6:48 am
by Lachlanp
Yes, I am runnin version 2.6
Regards
Lachlan
Posted: Fri Feb 08, 2013 6:51 am
by seulater
Not sure what to tell you, maybe try re-installing the package.
here is what i have in mine and you should as well.
