SBL2E GPIO Server Question
Posted: Thu May 17, 2012 8:21 am
by bbowden
I'm working on a project where I'm using a SBL2e-200IR GPIO pins and I need to signal a remote computer that a change has been made on an input pin. I could use polling of the GPIO server to check input pin state but I was wondering if there is anyway to have the SBL2e send a message that can trigger a scan of pin state...
Brett Bowden
Re: SBL2E GPIO Server Question
Posted: Thu May 17, 2012 11:19 am
I'm confused by what you mean by:
If I understand your system correctly, there's only the SBL2E with it's GPIO pins and a remote machine that it needs to tell a pin has changed. Do you mean to ask if there's a way that the remote machine can send a message to trigger a scan of the pin state?
Or do you mean that you can have the remote machine poll the SBL2E as to it's pin state and the SBL2E to notify the remote machine when the pins change and what state they are?
The answer to both is yes, but you'll need to clarify if you want more details.
Posted: Thu May 17, 2012 2:36 pm
by bbowden
To clarify... I have inputs connected to the SBL2e. When those inputs change state, I'd like the SBL2e to notify a remote computer that a change has been made.
At that point, either the remote computer can read all the SBL2e pin states to determine what has changed
OR
the SBL2e can tell the remote computer what input changed.
One caveat... I'm trying to do this with the standard programming that comes on the SBL2e-200.
Posted: Tue Jun 05, 2012 10:00 am
Oh, short answer: no. At least not with the default factory app. You'll need to have the NNDK and write a custom app.
While it might be possible to put this in as part of the default app, I believe the reason for leaving it out is due to the level of timing detail that users
would undoubtedly want, and whether or not the SBL2E could give that. There's also the fact that the standard factory app only has 584 bytes
of RAM left unallocated.
