I started playing around with the NetBurner (I'm new to it) and started messing around with the example code. What I wanted to do is modify the TCP_MultiSocket code so that upon a specific command, it will writestring of all connected IP addresses to whoever wrote the command. As I was testing it, it worked, with the exception that after I use the command, every client OTHER than the one that used the command get disconnected by the code in the
if ( FD_ISSET( fd_array[i], &error_fds ) )
iprintf( "Error on fd[%d], closing connection\r\n", i );
close( fd_array[i] );
fd_array[i] = 0;
ip_array[i] = 0;
