I'm new to the world of ethernet connectivity and working on my
first project leveraging the SB70LCApp example. I'm trying to write
an integer variable to the webpage and haven't been able to get writestring
to work properly. I've been successful using writestring to write static information to the webpage - [writestring( sock, " The Grounding Switch is Open <BR> <BR> \n" );] .
Is writestring the proper tool or should I be using a different method?
Greg
Newbie - How do I writie a variable to web with writstring
greg_edwards
Re: Newbie - How do I writie a variable to web with writstri
take a look in your nerburner example folder at this example and see if that is what you are looking to do.
C:\nburn\examples\Web\HtmlVariables
writestring only writes text, and you are trying to write an integer, correct? Try using siprintf() to crate a string out of the integer, then use writestring(). Note that you need to use sprintf() if doing floats.
greg_edwards
Thanks for your help. I used siprintf() and then write() and it correctly wrote the integer variable to the web page. Mucho Gracias!
Greg
Greg
