broke boot monitor
mphelps
broke boot monitor
Post by mphelps »
I reserve 0x30000 space for data, mistakenly wrote a few thousand more byte than I should have. No more more boot monitor appearing. This is one of the 5270 devices. I'm not knew to this, I have plenty other devices to know everything is setup fine, this devise doesn't show boot monitor in MTTTY on reset. Is this recoverable?
Musco
Re: broke boot monitor
Post by Musco »
Any solution to this problem yet?
If you overwrite the boot monitor you need to RMA the unit to be reprogrammed.
Ememdems
Post by Ememdems »
pbreed wrote:If you overwrite the boot monitor you need to RMA the unit to be reprogrammed.
Any other workaround?
