Did you 'brick' your MOD5441X or NANO54415? Look here...
mhyun
Re: Did you 'brick' your MOD5441X or NANO54415? Look here...
Post by mhyun »
edit: never mind, just figured it out
russ58
Post by russ58 »
I can connect to my NANO54415 via MTTTY.EXE, all seems a-ok. I enter FLA and start a download. The NANO echoes back 3 "x" characters and then sends a bunch of "*" characters. This goes on a long period of time (lots of stars). Then it responds with this:
***********************************************xREturned without programming
Download failed
nb>
As you can see it went back to a single "x" and then a textual error message.
Anybody have a clue as to what to look for? I've repeated this several times, each with the same result.
What is the exact file name you are downloading?
russ58
Post by russ58 »
Turns out the -H switch on compcode will cause this behavior. Removing the -H switch fixed the problem.
