Page 4 of 5
Re: NANO54415
Posted: Thu Apr 05, 2012 1:24 pm
by fanat9
Nano54414 product page - Q3 2012.
Re: NANO54415
Posted: Thu Apr 05, 2012 1:26 pm
by seulater
yes, but its not in the store to pre-order
Re: NANO54415
Posted: Thu Apr 05, 2012 1:35 pm
It should be available in late Q2.
Re: NANO54415
Posted: Thu Apr 05, 2012 1:48 pm
by seulater
ok, but when will the site have it for pre-order?
right now you can only pre-order the MOD54415 Ethernet Core Module, but not the nano.
Re: NANO54415
Posted: Thu Apr 05, 2012 2:41 pm
by bbracken
I would be interested in this concept... particularly interested in display and audio.... the 2 things that are missing from the standard NetBurner boards.
bb
Re: NANO54415
Posted: Mon Apr 09, 2012 7:19 am
by Ridgeglider
Hi Paul: I know you're trying to minimize cost on the NANO54415, but as you consider its dev board, I'd encourage you to add SD support in either an SD or microSD adapter format, as well as including at least a few gpio LEDs and SW inputs like the ones that are on the DEV70 boards. If these can't be added to the dev board itself for cost reasons, another idea might be to offer a module that piggybacks onto all or part of the NB J2 connectors to add quick SD slot / LEDs / Switch inputs to any of you "MODd52xx" platforms.
The Nano54415 looks like a great platform!
Re: NANO54415
Posted: Mon Apr 09, 2012 10:06 am
I just sent the "new" dev board for the NANO out for fabrication.
It has 5 LED's 1 power, and 4 connected to GPIO.
It also has a micro SD connector.
All nano pins go to un-populated header pins.
Power via Jack or USB
Uart 0 -> USB (With a jumper to disconnect the RX line so you can do TTL over the header pins connector)
Uart 1 -> DB9(With a jumper to disconnect the RX line so you can do TTL over the header pins connector)
Uart 2 -> RS-485(With a jumper to disconnect the RX line so you can do TTL over the header pins connector)
CAN interface chip.
Re: NANO54415
Posted: Mon Apr 09, 2012 10:14 am
by Chris Ruff
did you remember to pull the two USB host pins out of the BGA for me?
Re: NANO54415
Posted: Mon Apr 09, 2012 10:34 am
The USB host or Device interface is selectable by stuffing or not stuffing two resistors.
So the nano brings out the pins for either host or device USB.
The default stuffing will be device.
Re: NANO54415
Posted: Mon Apr 09, 2012 4:34 pm
by Ridgeglider
Thanks! Sounds great!
