Can anyone Get Helios working?
Re: Can anyone Get Helios working?
Paul,
Sorry, I should have mentioned that I tried that before downloading the 32 bit version of Helios. It didn't work. I don't know enough about how eclipse and plug-ins work under the hood but I'm guessing there is just an impedance mismatch between the 64 bit version of Eclipse and 32 bit based plug-ins. Running a 64 bit version of Helios isn't at all important to me. I happy to be able to run the 32 bit version. It would be nice to be able to get those run configuration tabs to show up though.
Tod
barttech
Post by barttech »
I have loaded 32 bit Helios and am having the same successes and problems as Tod. Works for now, but I'm not sure how I'll start a new application without the Netburner tabs and fields working.
Sam
I was doing some work in Helios with our plugin today. I have everything working but the run configurations. Eclipse changed the way it creates run configurations, which explains the tab groups error you are getting. There's no simple way around it, it was not deprecated, but erased from the CDT plugin. So, that section will have to be rewrote. No way to get it working in helios until that is done...
fanat9
Post by fanat9 »
that's not good =(((
Forrest did you try speak with CDT guys ?
