Sorry, I'll have to go edit the article. It should have mentioned that the point of creating the InitalizedWrapper() method (initialize_wrapper () in your code), was so you could declare it static in your .h file. It should look something like this:
static void initialize_wrapper (void* const pTaskBase);
We still need the first parameter to OSTaskCreate to be a static (or non-member function) but inside our wrapper is where we "trick" it into actually using a member function. Let me know if this works. I do actually use this technique in my code so it does work.
Tod
