Updating SNMP for v3.x Project
Re: Updating SNMP for v3.x Project
If that is the case, I would run a quick test by creating and building an example that uses the file system in 3.x. Note that you cannot copy any system files from 2.x releases. I recommend \nburn\examples\EFFS\Fat\Http
I'm not getting any errors for any examples that use the file system, so I do not recommend changing udefs.h
I think you will need updated code from DMH for SNMP in 3.x.
