Page 2 of 2
Re: how to close secure websocket properly
Posted: Tue Mar 16, 2021 2:26 pm
by RebootExpert
Thanks Jon, I set m_fd_tcp to public and rebuild system files.
My thought to close ssl_fd first is incorrect. close the ssl_fd before close ws_fd in the same task doesn't solve the problem in 2.9.5, but work fine in 2.9.3
Interestingly, if I close the ssl_fd in a different task, application work completely fine. (false in 2.9.5, true in 2.9.3)
One thing I notice by using your code, whenever the return ws is null, I am able to close the ws_fd. If the ws is not null, and it's a secure ws, it's always fail to close the ws.
task to monitor ws fd
void wsTask(void *pd)
	char msg[ETHER_BUFFER_SIZE];
    fd_set read_fds;
    fd_set error_fds;
    FD_ZERO( &read_fds );
    FD_ZERO( &error_fds );
	printf("------------wsTask running----------------\r\n");
	while(true)
		OSTimeDly(TICKS_PER_SECOND/8);
		for(int i =0; i < ws_vector.size(); i++)
			FD_SET(ws_vector[i], &read_fds);
			FD_SET(ws_vector[i], &error_fds);
			select(1, &read_fds, NULL, &error_fds, 0);
			if (FD_ISSET(ws_vector[i], &error_fds))
				printf("webpage is closed by user, removed ws = %d from ws_vector\r\n", ws_vector[i]);
				int sslFd = 0;
				NB::WebSocket* ws = NB::WebSocket::GetWebSocketRecord( ws_vector[i] );
				if( ws != nullptr )
					sslFd = ws->m_fd_tcp;
					printf("ws is not null\r\n");
//					if(IsSSLfd(sslFd))
//						printf("sslFd = %d\r\n", sslFd);
//						close(sslFd);
//						printf("close sslFd succeed\r\n");
					printf("ws is null\r\n");
				close(ws_vector[i]);
				printf("close ws= %d\r\n\r\n", ws_vector[i]);
				ws_vector[i] = -1;
				ws_vector.erase(ws_vector.begin() + i);
				i--;
				continue;
2.9.5 debug output
added ws=38 to ws_vector, associate sock = 25, sock is not ssl fd //non secure webpage open
webpage is closed by user, removed ws = 38 from ws_vector
ws is not null
close ws= 38
added ws=39 to ws_vector, associate sock = 38, sock is ssl fd //secure webpage open
webpage is closed by user, removed ws = 39 from ws_vector
ws is null
close ws= 39
ws is null
close ws= 39
ws is not null
//fail to close. no print out
Posted: Wed Mar 17, 2021 9:35 am
by RebootExpert
I switch back to 2.9.3 since it works fine by using Jon code, the only thing I just need to change m_fd_tcp to public in the WebSocket class and rebuild the system file.
Posted: Wed Mar 17, 2021 10:04 am
by Jon
Hi RebootExpert,
Thank you very much for taking the time to run that and report what you found. I'll test this in 2.9.5 and see if I can't figure out why it's having issues. It sounds like we might have some additional changes to make. In the meantime, I'm glad to hear that you've found a solution for your current issue. Please let us know if you need anything else.
Kind Regards,
Jon
