I fixed the gateway issue. It wasn't a wrong InterfaceBlock. I was putting the gateway ip in the wrong place. So that works. And I can switch between Static and DHCP with impunity. I just can use tcp/ip or auto-update when in Static IP.
Looking through the autoupdate.cpp I see that it has lots of debug statements. So I built a debug version of my program and loaded it. Then I tried to load a release build while in Static IP. It loaded! But it didn't output a single debug statement. I then tried to load the same release build again, and it failed.
Changing between Dhcp & Static IP
Re: Changing between Dhcp & Static IP
What's your static IP settings? Does it have a gateway registered? If not, does the destination IP fit in it's subnet?
I copied the function DisplayRuntimeSettings() from NNDKProgman.pdf example on page 24 to my program and call it after every change of ip settings.
On power-up, with DHCP enabled, this is the output:
--- RUNTIME IP SETTINGS ---
Values assigned by DHCP Server
IP runtime settings using Interface Functions for interface 1:
IP: 10.250.5.85
Mask: 255.255.255.0
Gate: 10.250.5.1
DNS: 10.250.4.229
IP runtime settings using GetInterfaceBlock() for interface 1:
IP: 10.250.5.85
Mask: 255.255.255.0
Gate: 10.250.5.1
DNS: 10.250.4.229
Interface Name: Ethernet
I change the mode to static ip, and this is the output"
IP: 10.250.5.127
Mask: 255.255.255.0
Gate: 10.250.5.1
DNS: 0.0.0.0
IP: 10.250.5.127
Mask: 255.255.255.0
Gate: 10.250.5.1
DNS: 0.0.0.0
IP: 10.250.5.85
Mask: 255.255.255.0
Gate: 10.250.5.1
DNS: 10.250.4.229
IP: 10.250.5.85
Mask: 255.255.255.0
Gate: 10.250.5.1
DNS: 10.250.4.229
IP: 10.250.5.127
Mask: 255.255.255.0
Gate: 10.250.5.1
DNS: 0.0.0.0
IP: 10.250.5.127
Mask: 255.255.255.0
Gate: 10.250.5.1
DNS: 0.0.0.0
Lets go waaay back to basics.
Buid a default netburner app
then use the ipsetup tool to switch back and forth between DHCP (an address of 0) and static.
Verify that both ways work... I just want to be 100% sure the static address works correctly on boot without the switch...
Paul.
It could be a netowrk interface issues with ipsetup and autoupdate and have nothing to do with your switch code.
How many interfaces on your PC and what are there ipaddresses?
Paul.
You're correct, it's a network issue with our network. I moved to another subnet and it tried with a different static address and it works. Our "crack" IT dept is looking into it.
Thanks for all the help.
