Thanks for the very detailed instructions.
I will try this.
Jeff
Send Via on Mod 54417
jsearleEOC
Re: Send Via on Mod 54417
I am able to perform you test from my laptop(windows machine) For some reason I cannot get this netburner to talk directly to the hardware I am using. I can use only one port but much have a switch for it communicate.
I am able to communicate directly to this device with a MOD54415 Rev1.5 board and also my laptop with the same cables. IS there something I am missing electrically between the 54417 and the 54415. That seems like a silly question but is all I can think of being different.
One difference is the configuration. Seems like you are in individual port mode. What are the IP settings of: your PC, 54417 port 1, 54417 port 2, and what you are referring to as your hardware?jsearleEOC wrote:I am able to perform you test from my laptop(windows machine) For some reason I cannot get this netburner to talk directly to the hardware I am using. I can use only one port but much have a switch for it communicate.
Can you clarify what the difference is between your hardware and the laptop? Do you have other network hardware you made yourself?
