Page 2 of 2
Re: MOD 5282 MEMORY/FLASH TEST
Posted: Tue Dec 09, 2014 3:07 pm
by tpannone
rnixon wrote:One thing you could do is write a new small program that just erases the user parameter area, then load your code again and see if it works.
That's exactly what I was thinking about doing. I saw some other threads about using the SaveUserParam function to erase the User Params block in Flash. I was doing some digging to find out exactly SaveUserParam does.
And thanks for the other notes on using Flash.
Posted: Tue Dec 09, 2014 5:16 pm
If you look in userparam.c you will see the SaveUserParam() function, which works like:
USER_ENTER_CRITICAL();
FlashErase( ( void * ) &UserParamBase, len );
FlashProgram( ( void * ) &UserParamBase, pCopyFrom, len );
USER_EXIT_CRITICAL();
You could create a new function called EraseUserParam(), just delete FlashProgram(). If you create a function in userparam.c you need to rebuild the libs. If you include it in your app (there is a SaveUserParam example), you'll need to include the headers to call the flash and os functions
Posted: Thu Dec 11, 2014 7:21 am
by tpannone
rnixon wrote:If you look in userparam.c you will see the SaveUserParam() function, which works like:
That did the trick. After erasing the entire user parameter storage area in Flash, my original app works as expected and I can use IPSetup and AutoUpdate apps.
Now I need to look at what caused the problem in the first place. I believe it may be a case of operator error. Our user Flash contains various parameters to tune multiple servo loops. The field tech was telling me that in his frustration to discover and eliminate a servo loop instability, he was punching our 'Save to Flash' button pretty fast because he was making changes to operating parameters so quickly.
On an unrelated note, it's a little surprising to notice the differences in the various NNDK versions. My function is actually called SaveUserParameters() and is located in the system.c file.
Thanks again for the assist!
