NNDK 2.6.9 HTTP Trap
roland.ames
Re: NNDK 2.6.9 HTTP Trap
Post by roland.ames »
I am not familiar with the Nano, but with other modules, the system/autoupdate.cpp function DoData() has
      if ( ( ( pDr->dwThisAddr + pDr->dwThisLen ) >
             ( pCurRecord->dwUpdateBaseAddr + pCurRecord->dwDataLength ) ) ||
           ( pDr->dwThisLen > 492 ) )
         pDr->bAction = UPDATE_RESULT_ERROR;
         if(watchdog_service_function)
            watchdog_service_function();
         memcpy( pCurRecord->pData +
                 ( pCurRecord->dwLastRxAddr - pCurRecord->dwUpdateBaseAddr ),
                 pDr->bData,
                 pDr->dwThisLen );
         pCurRecord->dwLastRxAddr += pDr->dwThisLen;
         pDr->dwThisAddr = pCurRecord->dwLastRxAddr;
         pDr->bAction = UPDATE_RESULT_ACK;
as long as you have a line somewhere like
watchdog_service_function = MyServiceFunction;
you should not have watchdog reset during autoupdate
It's not Autoupdate that's failing it; it's the flash operations. They're inside a critical section and the bus is only running at 2MHz for all Nano's running monitor version 1.00 (shipped prior to Jan 2015). The nano doesn't have a watchdog service handler in the flash ops either, nor in the monitor. We've addressed the issue of missing handler in the flash ops, but the monitor is an interesting issue...
For the watchdo issue... the ocde that does the flash programming is in the source.
You should be able to add a watch dog "tickle" in that code.
