NNDK 2.6.7 Beta release available
Re: NNDK 2.6.7 Beta release available
Lance,
You are correct about the Nano SaveUserParams. There's a fix that was made on 1/15/15. Send us a ticket and I'll get you the files.
On the TCPSpaceAvail functions: Damn! You found my hidden code. I added these when implementing the non-blocking code for Websockets, but wasn't certain on exactly how they should be brought out/if the interface was correct.
These will actually be part of a overhaul to the writeavail and dataavail iosys functions we have planned. Basically, writeavail and dataavail will change from returning a boolean int of 0 or 1 to returning the byte counts available for writing or reading. This will also apply to ExtraFDs by way of adding two additional function pointers for doing the count based availability. If those function pointers don't get populated, then it will revert to the WriteAvail and DataAvail bits currently used, and only return a boolean int.
