* Fixed debugging timeout/disconnect/breakpoint errors
* Fixed missing library error when changing platforms in a projectI am guessing that my issues relate to the "timeout" fix not adequately addressing the long delays I have to deal with when debugging in the field. It would be difficult for support to replicate my problem, if it does relate to my field set-up.
On a fast PC running Windows 7, connected to the board by wire through a router, I don't have problems with the debugger, so not being able to replicate the problems in the "lab", I have hesitated to open a support ticket. Also, the device is working well now in the field and I haven't had to use the debugger out there lately.
Since there are not a lot of developers jumping in on this issue, either only two of us use the debugger, or no one else is having these issues.
Hope this helps you make your decision.
Ed
