NNDK 2.7.1 Beta release available
NNDK 2.7.1 beta release is now out and available for download on the NetBurner tools download page. Please report any issues in this thread or directly to support by submitting a new ticket at http://support.netburner.com.
Release 2.7.1 (March 2015)
New in this release
    FTP
        Added SYST command
    MOD54415
        Adding I2C driver examples
        Added 5441x IRQ 7 example
    NANO54415
        Added support for watchdog service routine during flash writes
        Updated monitor for faster boot times
    SBL2e
        Update Rev 1.66. Added support for UDP broadcasts. Corrected problem in initialization so device does not have to reboot for a change in outgoing destination IP address.
    SSH
        Added TCP keep alive to Secure Factory App
    System
        Adding precision support for %s in printf
        Added long long support to netburner printf
    Tools
        Java Autoupdate: Abort in auto mode now allowed
    TLS/SSL
        Implemented TLS 1.0,1.1,1.2
        Added support for SHA256 signatures
        Added support for SubjectAltNames to TLS and also for wildcard domain components
        Notes: Increased SSL/TLS stack size by 4k
    Websockets
        Adding Websocket Serial Console example
Corrections in this release
    DHCP
        GetDHCPIfNeccessary now checks to make sure that there is not already an IP assigned.
    FTP
        Fixed socket leaks with regards to issuing the PASV command
    MCF5441X
        Added link symbol for sim Rapid GPIO
        Restored EnablePHY and DisablePHY function
    MOD5282
        Fixed boot hang affecting release 2.6.9–2.7.0
    NANO54415
        Fixes Nano inability to write to UserParams
    NTP Client
        Fixed timetick overflow for NTP client devices that have been running without reset for more than 2 years
    UDP
        Add handler for IPSetup authenticate function for non-receiving interfaces
    Websockets
        Fixed TCP/WS deadlock issue on saturated links/lossy networks
ecasey
Re: NNDK 2.7.1 Beta release available
Post by ecasey »
The problem with lines 56 & 67 in bsp.c for the MOD5282 is still there.
http://forum.embeddedethernet.com/viewt ... &hilit=bsp
ecasey wrote:The problem with lines 56 & 67 in bsp.c for the MOD5282 is still there.
Well this is embarrasing. The release posted under 2.7.1 as the download used the 2.7.0 source tree. To be explicit, we built 2.7.1, tested 2.7.1, and then packaged 2.7.0 in to the install. I'm going to reupload this release with the correct source tree. Thanks for catching this.
/edit The installer was reuploaded yesteray.
mx270a
Post by mx270a »
2.7.1 on Win7 x64 with two network interfaces. With both interfaces enabled, NBFind doesn't find my module (NANO) in either NBEclipse or TaskScan. However, the module can be located in IPSetup and AutoUpdate. When I disable one network interface in Windows, everything is fine. I don't recall this being an issue with 2.6.7.
Also, like in 2.7.0, to get TcpGetTxBufferAvailSpace() to work I had to declare it in tcp.h. I mentioned this in the 2.7.0 beta thread. Do you not want customers using these functions, or did it just not get added to 2.7.1?
On the buffer function issue: Nope, I'm just an idiot. Somehow, between you mentioning them and me going to add them in the header, I forgot apparently... They're there now :/
With regard to NBFind: Is this the Eclipse find or the standalone find utility?
mx270a
Post by mx270a »
dciliske wrote:With regard to NBFind: Is this the Eclipse find or the standalone find utility?
The one in Eclipse. Both of my Windows network interfaces are enabled right now and this is what I get.
jwormsley
Post by jwormsley »
Is there any way to selectively disable different TLS versions? Can we, for instance, specify TLS 1.2 only connections, and refuse to connect to TLS 1.0 and TLS 1.1 servers?
Jeff.
