Coding Netburner in Ubuntu/linux
nicobari
Post by nicobari »
I am running Robotic Operating System (ROS) on Ubuntu and to set up my MOD54415 as a node for serial communication it seems I need to compile the code in Ubuntu (to use ROS libraries) or use another inefficient method which I am currently using (where I read data from MOD54415 into a ROS node and which then relays the information to other ROS nodes hence introducing delays). My question is there a way I can write codes and compile them for MOD54415 in Ubuntu?
Tanmay
Re: Coding Netburner in Ubuntu/linux
NetBurner uses gcc, is that what Ubuntu is using as well (exactly what does "compile under Ubuntu" entail)? If so, can you recompile the library(s) source code with the gcc from the NetBurner release?
faarizamar
Post by faarizamar »
Nothing needs to be done. When you start a new project, select the platform you want to use from the drop down list.
