Sharing source files between projects
sulliwk06
Post by sulliwk06 »
I have several source files that I am trying to share between multiple projects. Some of them are platform dependent so I can't make a library unless I make multiple libraries and rebuild them for each platform every time I make a change. I would think there should be an easy way to reference external source files in eclipse, but I can't find it.
Any ideas? or should I just suck it up and use a library for each platform.
dpursell
Re: Sharing source files between projects
Post by dpursell »
In v2.6.3, this works for me to link to an external file:
1. Right click on the project or folder you want the file in
2. Select New -> Other -> General -> File and hit next
3. Expand the "Advanced >>" pane
4. Select "Link to file in the file system" and use "Browse..." to select your file, then click Finish
I tend to have a set of "master" libraries for my main platform, then use this technique to create additional libraries from the same source when I need them on other platforms
dpursell wrote:In v2.6.3, this works for me to link to an external file:
I've used this method in th past for source files and headers.. Keep in mind that you cannot share the html directory though.
sulliwk06
Post by sulliwk06 »
This works for me, thank you.
