Large flash file system on NANO54415
sulliwk06
Post by sulliwk06 »
I'm trying to set up a 3MB file system in the flash on a NANO54415, but I'm getting errors on the mount and format commands when I try to make the file system larger than about 560kb.
I'm basing this off the EFFS-STD-HTTP example for the nano.
When the file system size is around say 512kB:
fd_mountstd() will return 2 and then the drive will be formatted properly
When the file system size is larger:
fd_mountstd() will return 3
then when I try to format the drive
fd_format() will return 1
All I'm doing is modifying the FS_SIZE macro of MX25L6406E.h
I don't understand what the return code from the fd_mountstd call means.
The EFFS error code it matches up with is "F_ERR_INVALIDDIR", // 3
I'm wondering if since the file system is larger I need to allocate more than 2 descriptor blocks, or if there is some other setting I need to modify. I know the file system isn't overlapping my program space because I modified the memory range in Compcode.
Anyone have any ideas? Anyone successfully used a large file system in flash before?
sulliwk06
Re: Large flash file system on NANO54415
Post by sulliwk06 »
It also appears to not let me place more than 8 files in the file system, regardless of each files size. I'm quite at a loss of what to do.
I have found the HCC Embedded EFFS Implementation Guide online and I looked up the call to fs_mountdrive which is giving me the first error I don't understand. Apparently the return code should be one of these:
FS_VOL_OK successfully mounted
FS_VOL_NOTMOUNT not mounted
FS_VOL_NOTFORMATTED drive is mounted but drive is not formatted
FS_VOL_NOMEMORY not enough memory, drive is not mounted
FS_VOL_NOMORE no more drive available (FS_MAXVOLUME)
FS_VOL_DRVERROR mount driver error, not mounted
But I can find no reference to what the values of these return codes are to see which one I am getting. Is this something I should open a support ticket for? Do I need to try to contact HCC Embedded for support?
Your walking into the land where mortals fear to tread... What your trying to do is somewhat ugly to accomplish, but entirely reasonable to do. Can you submit a support ticket to us about the issue?
It turns out this issue required that the filesystem have descriptors larger than a physical sector. We have modified the driver in the examples to support a multi-sector descriptor block. It requires that all descriptor blocks be set to be a power of 2 of physical sectors in size (4kB, 8kB, 16kB, 32kB, etc.).
