According to the PK70-NBPKX500-UsersManual.pdf, an example project is "included with the board"; however, I just got a box with two boards in it - no CD with files on it. Presumably I can get them (XilinxBladeGpio.v and XilinxBlade.ucf) somewhere on this site, but I couldn't find them.
Also, I cannot find any information regarding the pinout of the external connector. Of course, most pins are probably connected directly to PFGA pins, but I don't know which are connected to which.
So, where can I get the example files and the connector pin-outs???
FPGA Blade board example files and connector pin-out
Re: FPGA Blade board example files and connector pin-out
Should be in
nburn\examples\pk70\xilinxblade.....
This is installed with the PK70 tools, even if you don't have a FPGA blade you still get the code
The pinout is in the ucf file in that example.
The schematic is PDF schematic is attached...
- NBPKBX-500CR-SCH-R1p3.pdf
- (101.88 KiB) Downloaded 1091 times
Hi Paul,
Oh, but my tools are a little old - 2.4, IIRC. Is it possible to get the examples? Or must I upgrade the tools to get support there for the FPGA tools?
Bob
Bob
This has been part of the tools for a long long time...
It should be with any tools set after 2010....
What is in your nburn\examples\pk70 folder?
C:\Nburn\examples\pk70>dir
Volume in drive C is OS
Volume Serial Number is C41E-73D8
Directory of C:\Nburn\examples\pk70
07/11/2011 01:54 PM <DIR> .
07/11/2011 01:54 PM <DIR> ..
07/11/2011 01:54 PM <DIR> DigitalBladeDemo
05/19/2008 12:09 PM 551 makepk70
05/02/2008 12:21 PM 167 makepk70install
07/11/2011 01:54 PM <DIR> MBladeDemo
07/11/2011 01:54 PM <DIR> PK70FactoryDemo
07/11/2011 01:54 PM <DIR> Quad485BladeFactoryApp
07/11/2011 01:54 PM <DIR> QuadUartBladeFactoryApp
07/11/2011 01:54 PM <DIR> QuadUartBladeMMFactoryApp
07/11/2011 01:54 PM <DIR> QuadUartBladeSimple
2 File(s) 718 bytes
9 Dir(s) 95,801,577,472 bytes free
The release_tag file contains "Rel24_rc2"
2 File(s) 718 bytes
PM sent with a zip file.
Hi Paul, I got the PM, but there doesn't seem to be any attachment; I tried replying to the PM, but it seemed to get stuck in the Outbox - hopefully this makes it through...
I sent you a direct email with the zip file.
