When I Rebuild All System Files or Rebuild Modified System Files, it will do so for the 5213 platform, even though my project is for the 5441x.  If I go to Properties/Netburner Option and check that the platform is still MOD5441x, and then rebuild, it will do so for the correct platform (-DMOD5441x).  Is there a way to get the platform to 'stick'?
Sam
						Rebuilding system files, how to choose the platform?
Re: Rebuilding system files, how to choose the platform?
Choosing the project before you do the build seems to be the right way. I have many platforms and need to build the libs based on what I am currently using. I would not want the libs to build for a 5213 if I'm using a 54415.
Right, but I choose the platform when I'm working on a project.  Never is a problem if I'm compiling my own files.  But why, when I have just Rebuilt Modified System Files (with MOD54415), and I make a change and Rebuild again, does it use MOD5213 instead?
Sam
						Sam
I know the regular build is sensitive to your current context. If you open a source file from a 5441x project. Put your cursor inside that source file and then rebuild the system files does it do the right thing?
No, that doesn't seem to help.  All my files are from a MOD54415-based project.  Of course the system files aren't but I just tried what you said and it didn't seem to help.  If I go to Properties and check the platform (it doesn't change of course), that does the trick, it is just clunky.  I can live with it (I hope to not be modifying system files much), I just thought I was missing something.
Sam
Sam
