Updating gcc
ben71792
Updating gcc
Post by ben71792 »
I'm working on a net burner project and I'm getting internal compiler error. Is there a way to update gcc to a more recent version?
Re: Updating gcc
What error are you getting? Could you copy and paste in a build log?
ben71792
Re: Updating gcc
Post by ben71792 »
..\Serial.cpp
..\Serial.cpp: In function 'void Serial_ATC_worker(void*)':
..\Serial.cpp:164: warning: unused variable 'fd0'
..\Serial.cpp: In function 'void Serial_ACSES_worker(void*)':
..\Serial.cpp:258: internal compiler error: output_operand: invalid expression as operand
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://gcc.gnu.org/bugs.html> for instructions.
Time consumed: 8192 ms.
This happens when the optimization level is Optimize More (-O2). When its set to Optimize (-O1) it builds just fine.
donericb50
Re: Updating gcc
Post by donericb50 »
This is a "feature" of gcc when using nested swtich statements such when implementing an ASM. Please see the attached pdf. Building your own table based ASM is one way of solving the problem. This is actually not a version based problem ( from my experience ) with gcc.
gcc switch-complexity.pdf
(74.34 KiB) Downloaded 682 times
