PK70 Application Settings Programming Question
EyeStealth
Post by EyeStealth »
Newbie here.
I am new to embedded programming and wanted to know what is the best way to store application settings in the 5270.
I am writing an application that will have a web interface that will allow the user to set various application settings and I want these settings to be stored in non-volatile memory. If the PK70 is powered down and powered up, the application will start running and obtain the proper settings from this non-volatile area.
I thought about writing the settings to an ini file, but it seems to be that there is probably some better method for handling.
I appreciate your help.
If there are any examples that I can look at that would be best.
Thanks in advance.
Allan
Re: PK70 Application Settings Programming Question
Take a look at the example.
nburn\examples\web\flashform
That uses the Userparam space flash storage to save and retrieve a message that is non-volatile across power cycles.
EyeStealth
pbreed,
Thanks for giving me some help.
