Breakpoints not working
v8dave
Post by v8dave »
Hi all,
I have a simple test application just now and I can't get the debugger to stop at break points. The code is compiled as debug and I can see the debugger starting but it just carries on even if I insert break points.
Am I missing something in my build?
Cheers,
yevgenit
Re: Breakpoints not working
Post by yevgenit »
Sometimes, the compiler flag -gdwarf-2 disappears.
At Navigator window, right-click on name of your project.
In the context menu, select Properties.
At Properties window, select C/C++ Build, then Settings, then tab Tool Settings, then GNU C Compiler.
Verify, that the compiler command line includes: -gdwarf-2
The generic way of restoring the default project setting is to create the new project, verify the breakpoints are operating, and then import your own source files.
Yevgeni Tunik
________________________
yevgenit
Post by yevgenit »
Verify, the compiler command line has the following include (for mod5270):
-I"C:\nburn\mod5270\include"
Yevgeni Tunik
v8dave
Post by v8dave »
All of the above is correct for my MOD5234.
I'll create a new project and try it that way. This is just some test code so no big issue to go this extra step.
v8dave
Post by v8dave »
OK, I created a new project with defaults only and still it won't debug the breakpoints.
I have recently upgraded to the latest Rel24 RC2 and suspect this may be the issue.
yevgenit
Post by yevgenit »
My wizard-generated simple project has breakpoint feature fully operational.
I use Rel24_rc2.
Yevgeni Tunik
v8dave
Post by v8dave »
Can you set breakpoints in UserMain?
I had it working yesterday at one point with the same project but it is not consistent and I can't breakpoint anything before the while loop in UserMain.
yevgenit
Post by yevgenit »
My mentioned simple project has correctly operational breakpoints in UserMain() function before the while loop.
The source code is at http://forum.embeddedethernet.com/viewt ... ?f=7&t=676 ( Post subject: Ignoring ACK during master send without peripheral slave ack
PostPosted: 08 Apr 2010, 17:29)
If you need, the project files can be sent as well.
Verify check of "Network debug" while generation of the example project with NetBurner wizard.
Yevgeni Tunik
v8dave
Post by v8dave »
Hi there,
Yes, network debugging was checked and the code to enable the debugger is called within UserMain. I have a printf to confirm this.
Is strange that I can set some parts to breakpoint but others can not.!!
mhoyt
Post by mhoyt »
Dave, try putting a delay after the call to InitializeNetworkGDB_and_Wait(), like this:
  OSTimeDly (TICKS_PER_SECOND * 2);
I ran into this problem not long after I started using the Netburner a few months ago. I haven't investigated it any further, as the simple delay fixed the problem for me. I had noticed that breakpoints deep in the code worked, and placing breakpoints during runtime also worked, but not breakpoints appearing shortly after the InitializeNetworkGDB call.
--Mike
