Linksys WRT610N v2
blahartinger
Linksys WRT610N v2
Post by blahartinger »
Has anyone had success connecting a netburner 5270 dev kit with wifi dev kit to this router? I'm Trying to get the wifi infrastructre example to run and the wifi doesn't connect...I'm running with WEP 128bit encryption. Basically, I can see that it hangs on the debug output such as below.
Configured IP = 192.168.1.106
Configured Mask = 255.255.255.0
MAC Address= 00:03:f4:04:01:13
WiFi Infrastructure Example Started
Static IP address set to :192.168.1.106
--- ETHERNET RUNTIME IP SETTINGS ---
IP: 192.168.1.106
Mask: 255.255.255.0
Gate: 0.0.0.0
DNS: 0.0.0.0
Attempting to connect to network: [Shazam], WEP: [12345123451234512345123456]
Wifi: Warm start detected, resetting RTL8711
Wifi: EEPROM ID->8711
Wifi: Downloading Done
Wifi: BSSID 00:03:F4:04:2C:11
Wifi: Scanning
Wifi: Site detected Shazam
Wifi: Scanning Done
Wifi: Connecting
Re: Linksys WRT610N v2
Did you try a test in which you did not have the router or netburner use any encryption?
Is the SSID correct in IPSetup?
