Page 1 of 3
New Firmware
Posted: Mon Aug 15, 2016 7:22 pm
by Mike2545
Hey Guys!, Netburner released new firmware this month for the PINK. Anyone know what new features it has/ bugs it fixed? It did not come with a read me text explaining.
TBH I am impressed they are still supporting this, my earliest firmware version is SB70-PinkApp-R1p36-20110111_APP.s19 Date 12/21/2010
Re: New Firmware
Posted: Tue Aug 16, 2016 10:17 am
Release 1.46 8/1/2016, NNDK 2.7.6
- Added TLS support for email
Release 1.45 5/13/15
- Fixed problem with FTP. A transfer now reports an error if the file system is out of space.
- Added support for .js.gz compression of javascript
Release 1.44 4/30/15
- Added !NB0FW command to report firmware version
Release 1.43, 20150423, NNDK 2.7.1
- Added TLS support, the additional size required reduced the file system from 256k to 192k.
New range is 0xFFC0800 to 0xFFC50000 (previously 0xFFC4000)
- Added the ability to configure IP settings from the serial port, previously read only
!NB0WSI:<ip addr>, !NB0WSM:<mask>, !NB0WSG:<ip addr>, !NB0WSD:<ip addr>
- Added ability to change the web server port number (HTTP Port) on web interface and serial interface. !NB0WHP:<port>, !NB0RHP
Revision 1.38, 20131111
- Rebuilt with un-modified NNDK 2.5.3 and PINK source pulled from GIT on 2013.11.11
- Added ability to format file system on nb_factory.htm configuration page
Revision 1.37, Release20120216
- Modified application to be compatible with SB70 and SB70LC products
- Upgraded flash file system (EFFS-STD) from 1.63 to 1.91. EFFS is now thread safe, has
wear leveling
**** IMPORTANT: Versions are not compatible and require a format of the on-chip file
system
**** Save your files from the the SB70 device before uploading the new application or
they will be erased
- Additional status messages on file system initialization and reported usage. Viewable
on UART0 during boot
Revision 1.36, 20110111
- Rebuilt with NNDK tools 2.5.1; now supports the ability to send and receive e-mail with
SSL
Re: New Firmware
Posted: Thu Aug 18, 2016 1:06 pm
by Mike2545
Thanks TomNB.
I have an issue with my PINK SB70 that you may know the answer to. I can loop through my program and ask the pink what NBvar's are and push data to the PINk SB70 all day, but every once in a few hours my serin times out. When I look at the Telnet session the output is reading S L O W like one character every 30 seconds. My question is, am I reading the vars too quickly, is there a reset I can preform, is it a hardware issue? I am pulling my hair out trying to figure this out.
Re: New Firmware
Posted: Thu Aug 18, 2016 6:42 pm
Can you provide very specific details on the slowness? Can you tell from the telnet session when your query is received, and when the pink replies? I can't think of any reason this would happen. What revision are you running, and did this occur in the old one? As you can tell, the more information the better.
Re: New Firmware
Posted: Thu Aug 18, 2016 7:17 pm
by Mike2545
Ok, well
The queries are received then followed by a reply that in the telnet (putty) terminal says like "Sent to stamp:" or "Received from stamp" then the var comes across the telnet terminal real < s l o w >like ; 1 character per 30 seconds; !...N...B...0...W...1...1...:...7...4...<CLS>
I know it takes about 2 minutes for the PINK to clear the error.
Newest revision R1p46
and occurred in the old one R1p38
I run a serial debug terminal and have begun recording data in text files, Putty times out and is hard to decipher when an error occurs : My debug file to follow ...
PUTTY
Sent to Stamp:[]
Received from stamp:[!NB0W32:76<CLS>]
Set Var [32] to [76]
Received from stamp:[!NB0W31:76<CLS>]
Set Var [31] to [76]
Received from stamp:[!NB0ST]
Read Status value = 01
Sent to Stamp:[]
Received from stamp:[!NB0W72:46<CLS>]
Set Var [72] to [46]
Received from stamp:[!NB0W42:74<CLS>]
Set Var [42] to [74]
Received from stamp:[!NB0W41:73<CLS>]
Set Var [41] to [73]
Received from stamp:[!NB0W74:86<CLS>]
Set Var [74] to [86]
Received from stamp:[!NB0W73:95<CLS>]
Set Var [73] to [95]
Received from stamp:[!NB0W75:= 63<CLS>]
Set Var [75] to [= 63]
Received from stamp:[!NB0W76:83<CLS>]
Set Var [76] to [83]
Received from stamp:[!NB0W77:On<CLS>]
Set Var [77] to [On]
Received from stamp:[!NB0W80:69<CLS>]
Set Var [80] to [69]
Received from stamp:[!NB0W81:71<CLS>]
Set Var [81] to [71]
Sent to Stamp:[]
Received from stamp:[!NB0W82:78<CLS>]
Set Var [82] to [78]
Received from stamp:[!NB0W83:66<CLS>]
Set Var [83] to [66]
Received from stamp:[!NB0W94:06:45<CLS>]
Set Var [94] to [06:45]
Received from stamp:[!NB0W95:20:32<CLS>]
Set Var [95] to [20:32]
Received from stamp:[<CLS>]
Received from stamp:[!NB0W96:19:45<CLS>]
Set Var [96] to [19:45]
Sent to Stamp:[]
Received from stamp:[!NB0W02:74<CLS>]
Set Var [02] to [74]
Received from stamp:[!NB0W01:73<CLS>]
Set Var [01] to [73]
Sent to Stamp:[]
Timed out
My serial debug file
<MAIN 13:23:28 08/18/16>
Office Pass
Bedroom Pass
Diningroom Pass
Sunroom Pass
Living room Pass
Attic Pass
Solar Pass
Greenhouse Pass
<MAIN 13:23:41 08/18/16>
Office Pass
Bedroom Pass
Diningroom Pass
Sunroom Pass
Living room Pass
Attic Pass
Solar Pass
Greenhouse Pass
<MAIN 13:23:53 08/18/16>
Office Pass
Bedroom Pass
Diningroom Pass
Sunroom Pass
Living room Pass
Attic Pass
Solar Pass
Greenhouse Pass
<MAIN 13:24:06 08/18/16>
Office Pass
Bedroom
(timeout2) 13:24 Error # 1
<MAIN 13:24:20 08/18/16>
<MAIN 13:24:32 08/18/16>
<MAIN 13:24:44 08/18/16>
Crank-it -------------------------
<MAIN 13:26:14 08/18/16>
(timeout2) 13:26 Error # 1
<Setup Loading Data in Pink 13:26:26 | 08/12/16......... </Setup>
<System 2 Loading Temps in pink ......</System 2>
<MAIN 13:26:32 08/18/16>
ReSetting.......
Resetting PINK
Rebooting..............
REBOOTING
<Setup Loading Data in Pink 13:26:53 | 08/12/16......... </Setup>
<MAIN 13:27:00 08/18/16>
Office Pass
Bedroom Pass
Diningroom Pass
Sunroom Pass
Living room Pass
Attic Pass
Solar Pass
Greenhouse Pass
<MAIN 13:27:17 08/18/16>
Office Pass
Bedroom Pass
Diningroom Pass
Sunroom Pass
Living room Pass
Attic Pass
Solar Pass
Greenhouse Pass
<MAIN 13:27:30 08/18/16>
Office Pass
Bedroom Pass
Diningroom Pass
Sunroom Pass
Living room Pass
Attic Pass
Solar Pass
Greenhouse Pass
No way to know the time stamp on PUTTY
NOTE: these 2 terminal text files did not occur at the same time
Re: New Firmware
Posted: Fri Aug 19, 2016 7:16 am
by Mike2545
Here is a video of the telnet terminal I shot this AM. Sorry for the jerky camera work...
[youtube]vmc4MHwsY1E[/youtube]
https://www.youtube.com/edit?video_id=v ... rrer=watch
*looks like the youtube tags don't work
Re: New Firmware
Posted: Fri Aug 19, 2016 3:13 pm
We have run a unit here all day in a continuous loop reading the system vars and writing all 99 of the data vars as fast as it can, but have not been able to reproduce what we see on the video. We will let it run over the weekend. The video shows slowness on both the telnet debug and serial port, which is unusual because its rare for a serial port to have a problem like that.
Re: New Firmware
Posted: Fri Aug 19, 2016 6:03 pm
by Mike2545
Thanks Tom, I have also swapped out One PINK for another I had on the shelf , and still saw the same the error after a few hours. I am pushing data to the PINK then asking the status register if things on the web page have changed and get the time out.
Main:
debug cr, "<MAIN "
input SDA
input SCL
low SDA
DO
LOOP UNTIL (SCL=1)
I2CWRITE SDA,SCL, I2c_WR, [0] 'get time
I2CREAD SDA,SCL, I2C_RD, [Second,Minute,Hour,Day,Date,Month,Year]
date = 10*(date >>4) + (date & $0f) 'convert hex to bcd
month = 10*(month >>4) + (month & $0f)
debug hex2 hour,":",hex2 minute,":",hex2 second," ", hex2 month,"/",DEC2 date,"/",hex2 year,">",cr,10
serout2 pinktx,pinkbaud, ["!NB0W96:", hex2 hour,":",hex2 Minute, CLS]'put time on webpage
SEROUT2 pinkTX,pinkBaud, ["!NB0W99:",hex2 month,":",DEC2 date,":",hex2 year,cls]
serout2 pinktx,pinkbaud, ["!NB0W98:","0" ,dec day,cls]
SEROUT2 pinkTX, pinkBaud, ["!NB0ST"] ' Command To Read status Register
error = 1
SERIN2 pinkRX, pinkBaud,PauseBit,timeout2,[ Nb_varST ]' Get Data With Timeout
My serial screen shows the timed out routine pausing for 30 seconds
timeout2:
debug cr,"PINK not responding",cr,"Error code ",dec error
for x = 1 to 30
pause 1000
debug "."
next x
debug cr
goto main
Re: New Firmware
Posted: Sat Aug 20, 2016 8:03 am
Looking at your video again, the slowness is in the telnet session is "Received from stamp xxxxx". Looking at the source code for this, the telnet session is printing the chars from the stamp as fast as it receives them. So on second look it appears that the stamp may be the one sending chars slowly to the pink. How are you verifying that the stamp is sending at full speed? Can you verify there is no spacing between characters with an oscilloscope?
Re: New Firmware
Posted: Sat Aug 20, 2016 9:12 am
by Mike2545
Tom, the PIC (stamp) has timed out waiting for the PINK, if you look at the serial communicator screen to the right in the video, it is in the timeout2 subroutine, pausing for 30 seconds and going back to Main which tries to get the status register; "Error code 1" ,with the time stamps "09:26:04" & "09:26:43...etc" which it receives from an I2C RTC module, so it is indeed the PINK that is hung up maybe a buffer thing?
Nb_var 96 is the time which is [09:18] on the telnet screen, this slowness has been going on for 8+ minutes by the time I shot the video with the PIC timing out waiting for the PINK to respond to the command to read the Status Register (error 1)
