Port selection on PINK
Posted: Tue Oct 01, 2013 7:10 am
by sci_prez
I have number of monitoring systems deployed based on the SB70 with the PINK application.
When using a browser, I sometimes get a "page not found" message. I originally thought this was just one of those internet latency issues. But, I've recently found that even when getting a page not found error I can always use telnet to connect with the module.
In trying to isolate the problem, I'd like to use a different port for the SB70 (say 8080 instead of 80) to see if the ISP is blocking port 80 services.
Can I set the port used by the PINK?
Tom Sisk
Re: Port selection on PINK
Posted: Tue Oct 01, 2013 9:51 am
An easy test would be to connect the pc and pink to a router or switch, then you eliminate going through your isp.
Posted: Tue Oct 01, 2013 10:35 am
by sci_prez
Quite right.
During development on my local network this issue was not apparent. Its only when out in the field on a few sites that it becomes noticeable.
The immediate question is whether the PINK's port number can be easily changed.
Cheers
Posted: Tue Oct 01, 2013 4:02 pm
If you are building the pink app then its easy...
In the UserMain call StartHTTP just add the port you want...
IE
StartHTTP(8080);
If your using the default app there is presently no easy way to change it....
Posted: Wed Oct 02, 2013 5:28 am
by sci_prez
I was afraid of that!
We've been using standard application as it does everything we need and the client is very comfortable with it.
Is there a way to have a separate piece of code change the port number, without digging into the standard application?
Thanks for your insight.
Tom
Posted: Wed Jan 01, 2014 10:39 pm
by Herschel51
Thanks for sharing.
Posted: Sat Aug 30, 2014 1:29 pm
by Mike2545
You can set up a single port forward/redirect in the router. So when you do http://YourPinkAddress.com:8080 the router redirects to the internal IP address you give the PINK.
