Modifying vv_show.htm
Community forum for discussion and support of the PINK product and development kit
sci_prez
Post by sci_prez »
Hi folks,
I've got an piece of industrial equipment running in an isolated area. I've written a couple of html files for a PINK and an associated microcontroller which allow easy monitoring of the key parameters of the system's PLC controller.
The vv_show.htm is used set and save various other registers which we don't want a casual observer to have access to.
Is there a way to modifiy the text descriptions used in vv_show.htm so that the Nb_varxx's can have a clearer description? As an example, I'd put "Flow Meter Calibration" beside variable NB_var41, and so on. While working perfectly at the moment, the operater needs a "cheat sheet" in order to know what each variable is used for.
I'm hoping theres a way to ftp a modified vv_show.htm to the PINK. Any suggestions?
Tom
sb70koll
Re: Modifying vv_show.htm
Post by sb70koll »
Somewhere in the PINK example code or html files must be a NB_var41 text. I would create a project and load the PINK example code and search for that piece of text. Once you have found this text, maybe in a html file change it and recompile the PINK example code and flash your PINK. That is what I would do.
I'm new here and if someone has a better idea please correct me.
Corrected typos
Kind regards, sb70koll
Simplicity is my middle name - Danny Glover - Predator II
