PINK and Win7
Posted: Sat Mar 19, 2011 1:04 pm
From other forum posts I am thinking that I need new firmware to get the PINK SB70 modules to work with Win7. Is this correct?
Currently, when I attempt to run Netburner IP Setup V2.0 with the PINK Server Module, it does not see the module. From what I've read it *sounds* (if I am interpreting what I am reading correctly) like the new PINKs try to communicate using an address of 0.0.0.1 which Win7 doesn't like. I've tried other settings on the Win7 machine as well - manually setting IP addresses (no DHCP), different cables (crossover AND regular...)
How do I go about updating the firmware on the PINK modules I have (I have 5 that I had ordered through Parallax). Secondary question: Are these modules available through Netburner here in a Windows 7 ready configuration? Assuming that the earlier versions are not easily upgradable...???
Thanks very much for any assistance.
Dave Xanatos
Dave Xanatos
