printf and float
for everything else
jediengineer
printf and float
Post by jediengineer » Tue Sep 15, 2015 8:50 am
Not sure if this topic has been discussed before or not. I'm trying to output a double precision value to MTTTY. I'm getting weird numbers...
volatile double numberz[16]
numberz[0] = 5.01021;
numberz[1] = 3.33205
/// etc up to index 15
for (int i = 0; i < 16; i++) printf("Output: %2.6f\r\n", numberz[i]);
The output I'm getting at the terminal screen is:
Output: 21887.000000
Output: 14449.000000
What am I doing wrong?
Re: printf and float
Post by pbreed » Tue Sep 15, 2015 9:15 am
your example code is missing some ; so I assume cut and paste errors...
I ran the following code and got the correct result....
#include "predef.h"
#include <autoupdate.h>
#include <dhcpclient.h>
#include <smarttrap.h>
#include <taskmon.h>
void UserMain(void * pd);
const char * AppName="FloatTest";
InitializeStack();/* Setup the TCP/IP stack buffers etc.. */
GetDHCPAddressIfNecessary();/*Get a DHCP address if needed*/
/*You may want to add a check for the return value from this function*/
/*See the function definition in \nburn\include\dhcpclient.h*/
OSChangePrio(MAIN_PRIO);/* Change our priority from highest to something in the middle */
EnableAutoUpdate();/* Enable the ability to update code over the network */
EnableSmartTraps();/* Enable the smart reporting of traps and faults */
EnableTaskMonitor();/*Enable the Task scan utility */
volatile double numberz[16];
numberz[1] = 3.33205;
numberz[2] = 23.33205;
numberz[3] = 33.33205;
numberz[4] = 43.33205;
numberz[5] = 53.33205;
numberz[6] = 63.33205;
numberz[7] = 73.33205;
numberz[8] = 83.33205;
numberz[9] = 93.33205;
numberz[10] = 103.33205;
numberz[11] = 113.33205;
numberz[12] = 123.33205;
numberz[13] = 133.33205;
numberz[14] = 143.33205;
numberz[15] = 153.33205;
printf("Output: %2.6f\r\n", numberz);
while (1)
OSTimeDly(TICKS_PER_SECOND * 1);
jediengineer
Post by jediengineer » Wed Sep 16, 2015 7:15 am
Thanks Paul,
I must have had some form of typo in there. I deleted and retyped it and it worked. Thanks!
