NB_SSL_SUPPORTED and Code Size Problem
ecasey
Post by ecasey »
On a MOD5270B using version 2.9.5 I have a small subroutine for extracting data from the bottom of a std::list.
struct GraphData{
	time_t time;
	std::vector <float> value;};
float Graph::GetLastValue(int index){
	list<GraphData>::reverse_iterator D_it = plotData.rbegin();
	lastSavedMonth = gmtime(&D_it->time)->tm_mon;
	lastSavedHour = gmtime(&D_it->time)->tm_hour;
	return  D_it->value[index];
The "gmtime(&D_it->time)" lines cause a problem:
If I make the project with NB_SSL_SUPPORTED (1) commented out in predef.h I get 51 errors, mostly like:
C:\nburn\lib\cryptolib.a(wc_port.o): In function `wc_InitAndAllocMutex':
C:\nburn\system\cryptolib/wolfcrypt/src/wc_port.c:613: undefined reference to `wc_InitMutex'
C:\nburn\lib\cryptolib.a(ecc.o): In function `ecc_mul2add':
C:\nburn\system\cryptolib/wolfcrypt/src/ecc.c:8987: undefined reference to `wc_LockMutex'
C:\nburn\system\cryptolib/wolfcrypt/src/ecc.c:9075: undefined reference to `wc_UnLockMutex'
C:\nburn\system\cryptolib/wolfcrypt/src/ecc.c:8984: undefined reference to `wc_InitMutex'
If I enable the NB_SSL_SUPPORTED in predef.h, the code compiles to 131% of flash memory. I can get it down to 128% with optimization for size, but that is about it. The app compiles to 89% in version 2.8.6. Linker stripping is on in both cases.
Is there anything I can do to get this to compile with 2.9.5?
Re: NB_SSL_SUPPORTED and Code Size Problem
Are you using TLS/SSL?
If not I don't understand how that causes the Wolf ssl stuff to link.
Can you send a map file of the one that is 131% and open a support ticket?
ecasey
Post by ecasey »
Support ticket with map file sent.
It is definitely invoking cryptolib.a for the gmtime() function at line 327 in the map file:
Graph.o (gmtime)
ecasey
Post by ecasey »
Just for clarity, I am not using SSL/TLS.
This is an error, that should not be there.
Try using gmtime_r
You have to pass in your struct tm so its not globally allocated....and thus thread safe.
struct tm *gmtime_r(const time_t *clock, struct tm *result);
ecasey
Post by ecasey »
Thanks Paul,
It complies and links using gmtime_r() at 91.79% of flash with -O2 optimization and 88.98% with -Os.
I also found that it worked with localtime(), but that would require some work-arounds for daylight savings time to get back to GMT from EST/EDT.
Good point about thread-safe. That is a separate issue to gmtime() not working; I should hit gmtime() or gmtime_r() only once in that function. That will probably save me some grief down the road.
Ed
We will pull gmtime out of that location so it does not pull in the crypto world.
(I think there is a gmtime in the newlib as well... but its choosing the crypto one so... ):-(
