Re: SSL mutual authentication
Posted: Fri Sep 17, 2021 10:15 am
Hi Jon,
Thanks for the info. There's an issue I've found. As I set the client authentication to be mandatory, now all the other ports that are listening will mandate for a client certificate to be able to establish a connection.
To be more detail, device is accepting connection at two ports. eg 30000 and 40000 like this:
When the device boots up, if function1() get called first, it can establish a connection without a client certificate. However, if function2() get called later, it can also establish a connection without providing a client cert because a "certificate request" is not in server hello message during the handshake. Note, I already modified the cryptolib. Also this explain why I never saw "certificate request" but a reboot fixed it in my previous post in this thread.
If function2() get called first since device boots up, it can make a connection with providing a valid client cert. But now function1() will request a client cert too at port 30000 even it never ask for it. So it failed to make a connection. The "certificate request" now is included in the server hello message.
function1()
//doesn't require a client cert. eg port 30000
SSL_accept(listener, &address, NULL, 0);
function2()
// client cert is needed. eg port 40000
SSL_accept(listener, &address, NULL, 0, true, true, client_ca_cert, client_ca_cert_len, SSL_FILETYPE_PEM, nullptr);
