64-bit time_t
64-bit time_t
I'm using v2.9.1 with a MOD5441X, and testing the new 64-bit time_t parameter with the function below.
void TestDateTime( char *ptr )
   struct tm t, *timeinfo;
   char buf[20];
   iprintf( "Cmd: %s\r\n", ptr );
   memcpy( buf, ptr + 3,  4 );  buf[4] = 0;  t.tm_year = atoi( buf ) - 1900;
   memcpy( buf, ptr + 8,  2 );  buf[2] = 0;  t.tm_mon  = atoi( buf ) - 1;
   memcpy( buf, ptr + 11, 2 );	buf[2] = 0;  t.tm_mday = atoi( buf );
   memcpy( buf, ptr + 14, 2 );	buf[2] = 0;  t.tm_hour = atoi( buf );
   memcpy( buf, ptr + 17, 2 );	buf[2] = 0;  t.tm_min  = atoi( buf );
   memcpy( buf, ptr + 20, 2 );	buf[2] = 0;  t.tm_sec  = atoi( buf );
   if ( t.tm_sec < 0 || t.tm_sec > 59 )      t.tm_sec  = 0;
   iprintf("Yr: %d, Mo: %d, Dy: %d, Hr: %d, Mi: %d, Se: %d\r\n", t.tm_year,
        t.tm_mon,
        t.tm_mday,
        t.tm_hour,
        t.tm_min,
        t.tm_sec  );
  time_t tnum = mktime( &t );
  iprintf( "Before time_t = %lld\r\n", tnum );
  set_time( tnum );                           // Set System time.
  tnum = 0;
  time( &tnum );
  iprintf( "After time_t = %lld\r\n", tnum );
  timeinfo = localtime( &tnum );
  iprintf( "Yr: %d, Mo: %d, Dy: %d, Hr: %d, Mi: %d, Se: %d\r\n", timeinfo->tm_year + 1900,
        timeinfo->tm_mon + 1,
        timeinfo->tm_mday,
        timeinfo->tm_hour,
        timeinfo->tm_min,
        timeinfo->tm_sec  );
Output from function:
Cmd: _A%2050/08/20,08:58
Yr: 150, Mo: 7, Dy: 20, Hr: 8, Mi: 58, Se: 0
Before time_t = -1750339816
After  time_t = -1750339816
Yr: 1914, Mo: 7, Dy: 15, Hr: 2, Mi: 29, Se: 44
Why is time_t a negative number, and why is the date and time way off?
Re: 64-bit time_t
It appears that mktime is broken.
If I set the time to 2037 it works.
It I set the time to 2037 and then
tnum+=0x40000000;
I get this result:
Yr: 2071, Mo: 8, Dy: 29, Hr: 22, Mi: 35, Se: 4
So the the lcoaltime and the time processing is all working, the mktime function is broken...
I'll see what I can do...
Re: 64-bit time_t
For now this hack seems to work...
if((t.tm_year>137) && (tnum<0)) tnum+=0x100000000;
Re: 64-bit time_t
Fix for buggy mktime.
If you implement the hack above:
The "Hack" will have no effect if the function mktime is correctly implemented in the future.
If mktime is NOT fixed the hack above will fail to work correctly in the early 2100's.
If mktime is fixed the hack won't effect that and the early 2100's will be just fine.
So while I'm calling it a hack to fix the current buggy mktime you are 100% safe to put that in your code, and if you forget to take it out at
a later date (when mktime is fixed) its still ok.
Re: 64-bit time_t
Specifically the hack will fail again in 2174
Re: 64-bit time_t
Thanks, that seems to have fixed the problem.
Out of curiosity, wouldn't it have been easier to make time_t an unsigned long (DWORD) rather than a signed 64-bit value?
Also, this too appears to fix the problem:
time_t tnum = (DWORD) mktime(&t);
Re: 64-bit time_t
The new standard is 64 bit signed, so one can have dates before 1970.
Unsigned only works in one direction.
Re: 64-bit time_t
Ah! For the time travelers. I forgot about them.
Sorry. I couldn't help myself. :D
Re: 64-bit time_t
See time is not for just now, time is also used for dates and time in general, ie what was your birthday etc....
Some of us were born before 1970, so we need negative numbers....
