Page 2 of 2
Re: OSTaskCreate Return Values
Posted: Fri Mar 08, 2019 10:59 am
by tpannone
The change to 25 indeed fixed my problem.
I'm still not sure how I exceeded the 20 tasks limit but obviously the system thinks I did. I wish there was a way to query the system to tell me how many task control blocks are actually running since I think I have less than I actually do.
Posted: Fri Mar 08, 2019 11:27 am
by ephogy
There is a way.
#include <taskmon.h>
make a call to EnableTaskMonitor()
and run \nburn\pcbin\TaskScan.exe
There are number of system tasks that are created depending on what you use.
Idle Task (I don't know if this counts as one of the tasks or not)
Main Task (UserMain())
TCPD Task
IP Task
Enet Task
HTTP Task if you've called StartHTTP();
FTPD Task if you've called FTPDStart();
Also, if you look at predefs.h, there are a couple of things you can look at.
#define UCOS_TASKLIST
ShowTaskList();
#define UCOS_STACKCHECK
OSDumpTasks();
There might be more stuff you'll want, you can check out the uCOSLibrary.pdf file in \nburn\docs\NetBurnerRuntimeLibrary
Posted: Fri Mar 08, 2019 12:30 pm
by tpannone
Thanks ephogy! And thanks for quick tip on using TaskScan. I've seen it in the Netburner tools, but never looked into it.
As for the #define statements in predef.h, they are commented out in my copy so I'm guessing I'd need to uncomment them to use ShowTaskList() and OSDumpTasks().
/* #define UCOS_STACKCHECK (1) */
/* #define UCOS_TASKLIST (1) */
/* #define UCOS_TIME (1) */
/* #define BUFFER_DIAG (1) */
/* #define _DEBUG_PRINT (1) */
