sending a tcpip string via netburner
andiso
Post by andiso »
we need to send ascii strings like for example:
"abcd1234"
via tcpip and via RS232
I cant find any sample code for this in the examples folder
we are using the MOD5441x module
are there any code samples?
thanks
Jon
Re: sending a tcpip string via netburner
Post by Jon »
Hi Andiso,
There are several examples for both TCP and serial communications. From your NNDK install directory, you will want to go to examples\StandardStack\TCP and examples\StandardStack\serial, respectively. Hope that helps!
Kind Regards,
Jon
