I am trying to use some of the time functions of time.h and
nbtime.h, specifically
time_t timeNow;
timeNow = time( &timeNow );
I get a linker error for the function time.
and the other linker error get is on the function set_time;
time_t setTime = ( ( sysTime.tm_hour * 3600 ) +
( sysTime.tm_min * 60 ) +
( sysTime.tm_sec ) );
set_time( setTime );
This also gives me a linker error on the function set_time.
I have included the header files. And I know you aren't supposed to
include nbtime.h if you are using time.h and vice versa but when I excluded
either of them I still get the linker errors.
Is there a library I am supposed to be linking in?
time functions
time functions
Real Programmers comment code. If you can't explain it, you probably guessed.
