Problems on setup
Claudio
Problems on setup
Post by Claudio »
Good morning,
We made some devices using your MOD5417 and during their configuration we had some issues that we would like to clarify.
It states that these devices were inserted on a corporate network based on router / switch "Cisco Catalyst layer2".
The procedure adopted was as follows:
- MOD ethernet network connection, switch on the device;
- With IPSetup define the parameters: static IP, network mask (255.255.255.0), gateway, dns;
- Mode enabled switch;
- OK;
The test (preliminary) for proper operation is: display / operate the device via browser (port 80).
Problem: in some cases, at the end of the procedure, we could not get access to port 80 and even make PING the device?
Despite this, IpSetup, after configuration, however, see the device "alive".
Despite further reconfigurations it is impossible to access the port 80!
On these (problematic) devices, after 24 hours (without appling further changes on the device config) we could access the port 80. Do you have any idea why?
We're working with NNDK 2.7.5.
Claudio
