I have about 30 files, 1.5 to 3.9M long.
I modded the program to read 4096 bytes. And all it got was an initial 3584 bytes and no more.
the other errors about not reading the drive come about after the glitch happens. Once the glitch occurs, just resetting the device or sending a new program will generate the error. You have to power down to cold iron and poweron again to make the fault go away.
I was considering grabbing the file into ram all at once and read from ram. But that won't work either -- grabbing 4096 only gets me 3584 bytes.
so I'm stumped. Reading files isn't hard, so I don't think I"m doing it wrong. But I doubt EFFS has a problem either -- your stuff has been stellar. Thus, I'm stumped.
Problems with EFFS
Re: Problems with EFFS
I will try some file reading tests to try and reproduce.
I have been unable to reproduce an error so far. I am attaching my 3.3.9 build of the EFFS-HTTP example, modified to read and display a test .s19 file. To do the test:
- Load the effs-http app into your nano
- Use ftp or some other mechanism to unzip and put the TESTS19.S19 file on your nano flash card
- Connect to mtttty
- Run the example and use the new 'R' option to read and display the file.
I have run files as large as 2MB with no issues.
If this is not exactly what you are doing, modify the 'R' test processing an adapt it to your own file so we can test here.
- Connect to mtttty
- TESTS19.zip
- (18 KiB) Downloaded 121 times
- effs-http-src.zip
- (36.26 KiB) Downloaded 131 times
- EFFS-HTTP.zip
- (1.64 MiB) Downloaded 137 times
Hi shockwave,
Just checking back with you on this.
I had to put this aside for a couple weeks. I'll attempt the test this weekend.
