NB_SSL_SUPPORTED and Code Size Problem
ecasey
Post by ecasey » Fri Aug 05, 2022 6:12 pm
On a MOD5270B using version 2.9.5 I have a small subroutine for extracting data from the bottom of a std::list.
struct GraphData{
	time_t time;
	std::vector <float> value;};
float Graph::GetLastValue(int index){
	list<GraphData>::reverse_iterator D_it = plotData.rbegin();
	lastSavedMonth = gmtime(&D_it->time)->tm_mon;
	lastSavedHour = gmtime(&D_it->time)->tm_hour;
	return  D_it->value[index];
The "gmtime(&D_it->time)" lines cause a problem:
If I make the project with NB_SSL_SUPPORTED (1) commented out in predef.h I get 51 errors, mostly like:
C:\nburn\lib\cryptolib.a(wc_port.o): In function `wc_InitAndAllocMutex':
C:\nburn\system\cryptolib/wolfcrypt/src/wc_port.c:613: undefined reference to `wc_InitMutex'
C:\nburn\lib\cryptolib.a(ecc.o): In function `ecc_mul2add':
C:\nburn\system\cryptolib/wolfcrypt/src/ecc.c:8987: undefined reference to `wc_LockMutex'
C:\nburn\system\cryptolib/wolfcrypt/src/ecc.c:9075: undefined reference to `wc_UnLockMutex'
C:\nburn\system\cryptolib/wolfcrypt/src/ecc.c:8984: undefined reference to `wc_InitMutex'
If I enable the NB_SSL_SUPPORTED in predef.h, the code compiles to 131% of flash memory. I can get it down to 128% with optimization for size, but that is about it. The app compiles to 89% in version 2.8.6. Linker stripping is on in both cases.
Is there anything I can do to get this to compile with 2.9.5?
Re: NB_SSL_SUPPORTED and Code Size Problem
Post by pbreed » Fri Aug 05, 2022 8:38 pm
Are you using TLS/SSL?
If not I don't understand how that causes the Wolf ssl stuff to link.
Can you send a map file of the one that is 131% and open a support ticket?
ecasey
Post by ecasey » Sat Aug 06, 2022 5:37 am
Support ticket with map file sent.
It is definitely invoking cryptolib.a for the gmtime() function at line 327 in the map file:
Graph.o (gmtime)
ecasey
Post by ecasey » Sat Aug 06, 2022 5:53 am
Just for clarity, I am not using SSL/TLS.
Post by pbreed » Sat Aug 06, 2022 6:48 pm
This is an error, that should not be there.
Try using gmtime_r
You have to pass in your struct tm so its not globally allocated....and thus thread safe.
struct tm *gmtime_r(const time_t *clock, struct tm *result);
ecasey
Post by ecasey » Sun Aug 07, 2022 5:31 am
Thanks Paul,
It complies and links using gmtime_r() at 91.79% of flash with -O2 optimization and 88.98% with -Os.
I also found that it worked with localtime(), but that would require some work-arounds for daylight savings time to get back to GMT from EST/EDT.
Good point about thread-safe. That is a separate issue to gmtime() not working; I should hit gmtime() or gmtime_r() only once in that function. That will probably save me some grief down the road.
Ed
Post by pbreed » Sun Aug 07, 2022 3:16 pm
We will pull gmtime out of that location so it does not pull in the crypto world.
(I think there is a gmtime in the newlib as well... but its choosing the crypto one so... ):-(
