MODM7AE70
saram1
Re: MODM7AE70
Post by saram1 » Mon Apr 15, 2019 4:39 am
I was told by my system support that if I am using an internal network I should not have issue with firewall. Any way I will ask him again.
When I ran find6.py here are the results:
C:\nburn\pctools\find\python>find6.py
NOTHING was displayed.
I will check again with the system adminstrator and let you know.
saram.
ecasey
Re: MODM7AE70
Post by ecasey » Wed Apr 17, 2019 1:37 pm
Hi Saram,
Once you are sure that there is no firewall blocking on your PC,
Try this:
1. Start MTTTY;
2. Press the Reset button on the MOD.
3. As soon as you see the "Waiting 2 seconds...", press the "A" key ( that is <shift>+a).
4. That should put you in the bootloader.
5. From the NBEclipse Help tab select "Discover Netburner Devices".
Give it about a minute to load. If it shows no devices, press the "Launch IP Setup" icon in the NBEclipse task bar (it has an "IP" in the icon, just to the right of the center of the bar.
I found that this would get the Discover to work. I also had to do this a few times when a program wouldn't load while doing some testing.
Ed
saram1
Re: MODM7AE70
Post by saram1 » Thu Apr 18, 2019 5:58 am
Ed solusion didn't work for me.
I'm still wait for IPSetup.exe standalone from the support.
mayne this will help.
saram.
