NetBurner Community Forum
A community of NetBurner users gathering to discuss NetBurner hardware, software, design and projects
It is currently Sat Nov 18, 2017 2:41 pm
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Thu Apr 13, 2017 10:44 am
I'm currently trying to install a specific version of NBEclipse (2.5.2) and having issues getting it to launch correctly. At the end of the install process, an error dialog appears stating "Driver installation utility has stopped working". If I try to launch eclipse the application hangs after I select my workspace location at the 'loading workbench' stage.
I am running in a Windows 7 64-bit environment and have also tried running it using a 32-bit command prompt with no luck. A coworker was able to successfully install the application using the same executable. As far tell I can't seem to see a difference.
Other posts seem to not mention any issues during the initial installation of the app.
Top
 Profile
PostPosted: Thu Apr 13, 2017 2:28 pm
I've also added java (32-bit) to my path variable. Any further advice?
Top
 Profile
PostPosted: Fri Apr 14, 2017 9:35 am
This does not sound like any standard error that I am familiar with. Check your NBEclipse log file for hints. It will be located in the NBEclipse workspace, under .metadata/.log
_________________
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB® Forum Software © phpBB Group
